Creo 11 sketcher - box around dimensions
  • January 10, 2025
  • 872 views
Hello, we migrated from Creo 8 to 11. I have a problem in sketcher, those blue boxes around dimensions. Upon entering a value I cant even see the number. Any Ideas what could be the problem? I dont know if its graphical glitch or some setup/option problem.
Best answer by MartinHanak
please read https://support.ptc.com/help/creo/creo_pma/r11.0/usascii/index.html#page/model-based_definition/to_set_the_background_for_dimensions.html document.
You can also play around with the following config.pro options.
... additional suggestion:
Start Creo without using your specific config.pro files. This test will tell you whether the problem is caused by some config.pro option.
six1010-MarbleAuthor
Thank you, that was it.
So to specify, under options/entity display, sketcher background color default is now blue. I changed it to white, and that was the solution.
