Creo 12.4.1 material usage parameters are out of date
Hi Folks,
Moved to Creo 12.4.1,
Getting this notification every time I open a part or assembly: "Material usage parameters are out of date"
Only way to make it go away is to use the "Update Materials Usage..." command.
But that only lasts for that session, next time the files are opened, the message pops up again.
Is there some point or purpose other than to be annoying?
Regeneration does nothing to get rid of this notification.
Thanks for any wisdom shared.
