Creo 2.0 Distributed Batch.
  • July 16, 2015
  • 3 replies
  • 17754 views
Hello.
Im looking for any informations about distributed batch in CREO Parametric 2.0. In Pro/engineer i see was a small free program wchich help convert in one operation few .drw
to, for example: pdf format.
So,
1. My company have license to CREO parametric 2.0, but i wonder if CREO 2 have this type of module, (when yes), does my company have to
purchase another license for DB?
2. So second thing is, how to install it? Or maybe i can use some different optsion to do a batch processing some drw to pdf?
Best answer by MartinHanak
if Creo Distributed Batch is installed then there is ptcdbatch.bat file in Creo2_LOADPOINT\Creo 2.0\Parametric\bin drirectory.
In Czech environment I had to modify this file - I added the following line at the beginning of the file:
set PRO_LANG=english
When you launch ptcdbatch.bat file the following window will open.
Using UI you can define required action. DSM = Standalone enables you to run a batch on your PC, only. You do not need to buy special batch license.
On the other side, if you want to run batch on specific PC in your network, then you have to buy special batch license.
Martin Hanak
Mahesh_Sharma
22-Sapphire I
July 24, 2015
Creo Distributed Batch needs to be install as additional feature in Creo 2.0. This is available under Customize > Additional features when installing Creo 2.0.
i didnt see any Distribution Batch in customize> additional features while installation...
can you please tell  which option to select???
during installation you have to click Customize button
and check Creo Distributed Computing Extension item.
MH
Martin Hanak
Martin,
Can we access this function through VB API and perform required action?
OPERATION | STATUS | COMMENTS
Connected to Creo Pro | Failed | [-1] Error: General problem during data conversion.; C:\Program Files\PTC\Creo 3.0\M120\Parametric\bin\..\bin\parametric.exe
This is the error I get in the log file file after dbatch fails.
Mahesh_Sharma
22-Sapphire I
July 30, 2015
Did you mange to work on Distributed batch? If any of the information helps you, mark the appropriate replay as correct answer.
