Creo 2.0 M070 efx failed to load.....
Dear All,
I have installed Creo 2.0 M070. I have configured everything properly. AFX is enabled properly. Now when I am starting Creo it give a message that efx is failed to load. i know that the configuration efx is not in the newer versions of Creo and it's Configuration is AFX Enabled=Yes. Kindly help in this issue.
Thanks All
