The PTC Community will be on read only status starting March 23rd in preparation for moving our platform to a new provider. Read more here
Creo 2 Beam Simulation
dviberg
2-Explorer
Hi
I'm a frame designer from the Swedish Formula Student team "Elith Racing" and i've so far been using creo for designing and simulation. But ive recently found an issue where the simulation is acting weird.
What im doing is creating a frame using curves, then using creo simulation+ beam feature and some displacements. (See image)
The simulation is for finding the torsional stiffness of the design and checking for areas that might be in risk of deformation. The "acting weird" is that the resulting force from below simulation is way to high.
Simulation setting:
To calculate torsional stiffness i need the resulting force in on of the front displacements. There is one set of displacements in the rear that are set to fixed and one set in the front that rise one side 10mm and the lowers the other -10mm)
My questions:
Is it correct to use Measures (the one in the analysis area) > Quantity = Force, Reaction at Constraint / Components = Magnitude / Constraints = one of the front dispacements) to get the resulting force?
Is there a way to find the weight when using beam feature?
Is creo 2 simulation using beams reliable? (Same math right?)
Thanks!
Kind Regards
Daniel
0 REPLIES 0
