Creo 4.0 Floating License keeps dropping out
  • January 27, 2018
  • 2 replies
  • 6175 views
I downloaded the Academic Creo 4.0 Educational Edition.  It seems like my floating license is dropping out or timing out like every minute if I don't perform an action.
If I step away from my computer and come back, it will let me pan/zoom in and out in the 3d model space, but as soon as I do a command..it says I lost my license and retry, then it regains instantly.
I do a lot of online gaming so I would know if my internet was going in-and-out.
what computer is a license server for your Creo installation ?
dscho0091-VisitorAuthor
Just a good ol fashion Windows 7 desktop, the same computer that I am using the Creo Parametric on.
I am not trying to do anything fancy, I just installed the Creo Parametric 4.0 on my home computer and loaded the application after using the student edition license.
I just literally worked for about 6 hours straight and regained my license about every 2 minutes.
It seems to happen on actions.
So how would I go about fixing scenario 2?  Or even verifying if this is really the case?
Option 3 is not likely,  I do a lot of gaming online and would have noticed this.
11-Garnet
January 30, 2018
If you are using  a floating license, it might be a server setting.
We actually drop licenses every few minutes on purpose.
If we don't do that some users will never let go of licenses.
It becomes a real problem when you have various types of licenses.
I'd also definitely check if your network card doesn't go in to sleep mode after a few minutes. Creo doesn't connect to your server all the time like a lot of games and websites does, as you've noticed, it only pings the server once you activate a command.
