I am currently using Creo 8.0. When I use the USE EDGE tool on a drawing it only lets me select 3 or 4 lines any more and it deselects everything. Is there a setting to change this?
please upload your drawing (packed in zip file) and publish picture explaining what action do you want to do.
Sorry I seem to have marked the answer as a solution.
Unfortunately, I cant send you drawings as they are confidential. However, Please see attached snippet of the tool box.
When I open the drawing and go to Legacy Sketch - Sketching - Edge dropdown - Use Edge. Before I used to hold CTRL then click the relevant lines I want to highlight. I used to select 20/30/40 lines but now it only lets me click 3 or 4 lines before it deselects everything.
select Ent Chain option and using mouse surround rectangular area containing skeched entites,
thank you for the response.
I've just tried that but I get the same thing. It selected 3 lines then on the 4th it deselected them ones I'd selected previously.
I do not understand your problem. Please replay attached video.
