Creo Parametric 3.0 model tap disappeared
  • April 25, 2021
  • 6984 views
hello . while i was drawing i accidently closed the Creo but fortunately there is a file that i saved on the desktop. I tried to continue from where i saved, but i couldn't because i could not find model tap, so i can not run function " Revolve" and finish rest of the works.  On the picture, i think where i drew red circle,  there should be "Model Tap" . IF  anyone knows about it , please help me because i need to practice Creo for my exam and yet i have spend more than 2 days for figuring this by myself, and somehow i found this websites just now so i am posting this.....
You didn't post picture, but I don't get it, is the file is on the desktop why don't you just simply open it?
i am sorry , but i don't understand what you are saying.. On the picture, the one that i circled , there should be  " Model " tap but i can not find it ...
Okey... What happened is, you made part, while you were in part mode you made a sketch(in the part), and while you were in sketching mode you saved. This way it did in fact only save the sketch and no the whole part.
What you NEED to do is: Make a new part, make a new sketch in the part and then either remake the sketch there, or import your saved sketch file with this button:
Then you make make a revolve.
