Creo Parametric 3.0 model tap disappeared
  • April 25, 2021
  • 6984 views
hello . while i was drawing i accidently closed the Creo but fortunately there is a file that i saved on the desktop. I tried to continue from where i saved, but i couldn't because i could not find model tap, so i can not run function " Revolve" and finish rest of the works.  On the picture, i think where i drew red circle,  there should be "Model Tap" . IF  anyone knows about it , please help me because i need to practice Creo for my exam and yet i have spend more than 2 days for figuring this by myself, and somehow i found this websites just now so i am posting this.....
You didn't post picture, but I don't get it, is the file is on the desktop why don't you just simply open it?
i am sorry , but i don't understand what you are saying.. On the picture, the one that i circled , there should be  " Model " tap but i can not find it ...
kdirth
It appears in your image creo3 that you have created a new sketch file from the saved file.
Start a new part
Start a revolve feature in that part
Start a sketch in the revolve feature
Use the file system button to import the saved sketch
Click to roughly place the sketch
Adjust the scale to 1.0
Hold RMB to move the placement target to where you want it on the sketch
Use the placement target to place the sketch
Select the check mark to finish the sketch placement.
Finish your sketch
Complete the revolve
