Creo Parametric Accuracy as parameter
  • October 21, 2022
  • 3 replies
  • 1240 views
Good day, how i can insert accuracy in to parameter? I need show accuracy part in 3D note (flat to screen).
Thank you.
I think such parameter does not exist.
tbraxton
I do not believe it is a system parameter, but Modelcheck can get the value.
https://support.ptc.com/help/creo/creo_pma/r9.0/usascii/index.html#page/model_analysis/modelcheck/accuracy_info.html
Pliska10-MarbleAuthor
Thank you. So if this cannot be put into the parameter, I will solve it differently.
