Creo Parametric Student Version Drawing Template Frame
  • May 5, 2024
  • 3 replies
  • 5824 views
Hello everyone,
I've been working as a working student with Creo for quite some time now, so I decided to use it for a university project. Therefore, I downloaded the Creo Parametric Student 10.0 version and I'm on the verge of despair because I can't seem to find or insert a drawing template frame.
Unfortunately, the download didn't come with any frames or title blocks, and after intensive internet research, I still couldn't find any. I've already gone through all the relevant posts here as well.
Can someone help me and provide an A2 or A3 frame for this version? I've already manually created the title block according to ISO standards, but I can't find the exact data for creating the frame with letters, etc.
I would be extremely grateful for any help!!!
Best answer by Y_Yoely
Hi @MS_11022618
Have you tried the formats in the path: C:\Program Files\PTC\Creo 10.0.4.0\Common Files\creo_standards\formats?
Y_Yoely13-AquamarineAnswer
Hi @MS_11022618
@Y_Yoely wrote:
Hi @MS_11022618
I guess that formats cannot be opened in Creo using Student license.
So it is found in path C:\Program Files\PTC\Creo 10.0.0.0\Common Files\creo_standards\formats
try this link
http://apps.ptc.com/schools/references/templates.zip
Hi @MartinHanak
The ZIP file you shared does not contain the drawing format (.frm), so the drawing templates (.drw) do not even have a frame. As a result, it is not possible to create standard-compliant drawings from them.
@ProFeature wrote:
Hi @MartinHanak
my comments on your complaint follow ...
  • drawing template does not need to refer to the format
  • I did not share any zip file ... I provided link to package of templates provided by PTC, only
  • I did not check package contents
  • I am not responsible for what PTC provides
Please don't reply to my comments.
