Hello @mvicenzi
We may discuss in italian (I'm Italian/French guy), but let('s stay in English for others. Thanks for your movie. Related to this:
Hope this will clarify and help a bit as next step.
Serge
Hello @mvicenzi
I faced same issur first when trying to access article https://www.ptc.com/en/support/article/CS17031 We aplogy for this icnonvenience. However, when trying to access it again (a second time), the URL worked as expected. Maybe would you like to try accessing it again?
Anyway, this issue is due to the fact that:
Root cause of point 2 is probably due to the fact that dimension in drawing was created while option create_drawing_dims_only was set to yes in config.pro (default value being no). My suggestion to resolve this:
=> After having followed above steps, I expect you to be able to attached the DFS to the Drawing Dimension.
Refer then to article 17143 for a better understanding (pros versus cons) of what values yes and no drives in the system for this create_drawing_dims_only option
Serge
Hello @sacquarone,
Thank you for your answer.
I have just tried to do what you suggested but I keep having the same problem.
I closed Creo, set create_drawing_dims_only to yes, reopened Creo and recreated the drawing dimension, but I see the same error reported.
I attached some files to show you what I have done and the error shown (the picture shows the result of setting the file config.pro).
Hello @mvicenzi
Serge
