Creo Start Template Reference Datum Size
Hello community,
I've got a question related to a start template for 3D Parts in Creo. Is there a possibility to adjust the size of the reference datums? I know the parameter "datum_display_default" which is already set to "preconfiguredsize", "datum_outline_default_height" and "datum_outline_default_width" are also set.
The problem is that the first reference datums are not affected by this paramter. Is there another way to adjust these datums?
Many thanks and best regards
Christian
