Creo+ / Windchill relation and future updates
  • May 21, 2023
  • 2 replies
  • 3762 views
With the announcement of Creo+ (which is getting me really excited for the future of CAD and PTC taking the lead) I'm wondering, how do the 2 products relate to each other?
We are using Creo Parametric with Windchill at the moment. Will moving to Creo+ at some point eliminate the need for Windchill?  And will the files and its features be compatible / exchangeable with one another?
Happy to see your answers,
Jeroen
Jeroen
it would be better to ask your PTC VAR from whom you purchased the software.
My tips:
  • currently Creo+ data are saved in Creo Parametric 10.0.0.0 format
  • Creo+ does not eliminate the need for Windchill
To be clear Creo+ does not have a version format that relates to Creo parametric. You will not be able to open up a Creo+ model with on-prem Creo parametric without a translator.
I am almost sure that I read that Creo+ =  Creo Parametric 10.0, now. In 2024 it will be Creo Parametric 11.0, and so on.
PTC will tell you that Creo+ is meant to work best with Windchill+
They can both be externally managed and in the cloud.
