Creo and Model-Drawing associativity - Broken!
Dear fellow Pro/Engineer zealots,
My company obviously is evaluating Creo as a replacement for Wildfire 4.0 and in the process we are considering the Flexible Modeling and Direct Modeling Application to be included in that upgrade. We have discovered what we consider a MAJOR issue (we consider it a bug). We've all been reading and hearing about all of the great things that flexible (Direct) modeling give us. However, with this introduction, one of the key benefits of Pro/Engineer has been broken. If you add a flexible edit feature (either using the Flexible Modeling extension in Creo Parametric or using Creo Direct), drawing dimensions will not update. This is true for both shown and created dimensions.
What if the flex edit only moved a particular face by .05 mm? For the types of products we develop, this is often done. This could easily be overlooked. The picture below shows an example. The 3 red dimensions are the original dimensions. The geomety at the right side of the view was moved using a flexible edit feature by .05 mm. the 3 dimensions did not update. The 3 green dimensions were added after the flexible edit feature to show what the values should be.
We have decided that when we migrate to Creo, we will NOT be adopting Flexible Modeling or Creo Direct unless this has been fixed. There is too great a risk since 2D drawings are still our contractual document of record. Model to drawing associativity was one of the primary benefits for my company to switch to Pro/Engineer many years ago. We do not believe that we are the only ones that feel this is unacceptable and would like others to be aware of this issue. We would also like to hear other PTC customers' opinions as to the severity of this issue.
Kind Regards,
Ryan Gelotte
IT Engineering Analyst
TE Connectivity (formerly Tyco Electronics)
