Creo drawing lifecycle state in title block mismatches with Drawings state in Windchill
  • February 23, 2026
  • 114 views
Hello Team,
Could you please help me for below issue.
Creo drawing lifecycle state in title block mismatch with Drawings state in Windchill. But it is taking related CAD part/ASM Windchill state.
Thank you
Kumar B
Best answer by BenLoosli
By default Creo is pulling the lifecycle state from the first object (part or assembly) added to the drawing. If you want the drawing lifecycle state, add ':d' to the end of the parameter name. Example: PTC_WM_LIFECYCLE_STATE:d
Can you give more information? Maybe an image or the parameter that it's looking for.
Kumar_KB14-AlexandriteAuthor
Hi Arnold,
The drawing lifecycle state in Windchill should be Processing (newly created drawing). However, when I create a drawing using a CAD Part whose Windchill state is Under Change, the drawing’s title block shows the same lifecycle state as the .prt instead of the drawing’s own state. How can we fix this issue?
Kumar B
BenLoosli23-Emerald IIIAnswer
