Creo2 and Trace Sketch
  • July 10, 2015
  • 2546 views
In Pro/Wildfire ISDX we used to have a powerful little command called trace sketch.
I now have a need for it in Creo 2 and the command is not even in the menu mapper.
Where is it now?
Did it fall off the Creo 2.0 ribbon?
Why did we loose this functionality?
Here is a link to getting it done by applying a new material,
ProE Wildfire 4 - using outside images for reference
But the drawbacks here is you have to create features first and before we could control aspect ration, rotate and transparancy.
Best answer by dgschaefer
In Creo 1 they moved the functionality from ISDX to standard Creo. in Creo 2 they renamed it "Images".  It's on the view tab under the "Model Display" section.
This video shows the new functionality in Creo 1, I think Creo 2 is similar but you need to look for "Images" in the Model Display" pull down.
Thanks A LOT!
Talk about frustrating trying to find "Trace Sketch" when the command has been renamed to "Images" the search in the menu mapper was no help.
