Creo2 and Trace Sketch
Beyontech1
In Pro/Wildfire ISDX we used to have a powerful little command called trace sketch.
I now have a need for it in Creo 2 and the command is not even in the menu mapper.
Where is it now?
Did it fall off the Creo 2.0 ribbon?
Why did we loose this functionality?
Here is a link to getting it done by applying a new material,
ProE Wildfire 4 - using outside images for reference
But the drawbacks here is you have to create features first and before we could control aspect ration, rotate and transparancy.
In Creo 1 they moved the functionality from ISDX to standard Creo. in Creo 2 they renamed it "Images".  It's on the view tab under the "Model Display" section.
This video shows the new functionality in Creo 1, I think Creo 2 is similar but you need to look for "Images" in the Model Display" pull down.
LinkedIn
LinkedIn
Thanks A LOT!
Talk about frustrating trying to find "Trace Sketch" when the command has been renamed to "Images" the search in the menu mapper was no help.
