Dale_Rosema
Cursor not visible in family table cell
  • May 12, 2023
  • 4 replies
  • 4569 views
When editing a family table cell, the cursor goes AWOL (missing) and I have remember how many left or right arrows to edit text in a cell. I am using Creo 9.0.4.0.
Has anyone else experienced this?
Any thoughts to a solution.
Brand new systems with the specs called out for Creo 9.0.4.0.
Best answer by Dale_Rosema
Waiting for the next release:
in Creo 9.0.2.0 I can edit FT without problems. See video. I guess Creo 9.0.4.0 should work the same way.
Dale_Rosema
Can you check and see if when you are in an active cell and you press "F2" to edit the cell if the cursor shows up?
Then use the right and left arrows, too.
Q: Is text cursor displayed in active cell after hitting F2?
Creo 9.0.2.0 ... no
Creo 8.0.4.0 ... no
Creo 7.0.9.0 ... yes
Suggestion: I you have Excel installed then edit FT in Excel.
Patriot_1776
'Sup Dale!  I'm on Creo 8, but it may be a Windows thing.  We had issues with there not being a cursor on our "Red" systems, and it turned out to be windows settings (Use text cursor indicator)  and (Cursor blink rate).
Best of luck!
Dale_Rosema
I opened a case for cursor disappearing when editing a family table using "F2" key.
Case 16880414 has been opened
Dale_Rosema
FYI ... other users cannot access your Case 16880414.
Dale_Rosema
Another discovery:
When editing a cell in the family table using F2, if you Alt-Tab to another item you have open and then Alt-Tab back, the cursor is present and blinking.
Weird!!!
