Customised Table
  • February 25, 2017
  • 2 replies
  • 3655 views
I have a customised table for fetching all parts all parts from model tree . But the error in the table is it does not display alphabetically / in order of the model tree. E.G:- it goes like 001,003,002. but I need it configured as in order. Can anyone help. Attached is the file.
Thanks in advance
    2-Explorer
    February 27, 2017
    Hello Bhagyesh Vashi
    as far as l know: Default sort "parameter" in BOM tables is weight , if nothing has been specified in SORT BY.
    How to specify SORT BY parameter?
    1. Create desired BOM table
    2. Go to REPEAT REGION - SORT REGIONS
    3. Select desired BOM table
    4. Select EDIT in pop-up menu
    5. Text editor will open - here you can define SORT BY conditions
    - you can speicfy more parameters
        - first row is primary parameter for sorting
        - second row is secondary parameter for sorting
        - etc.
        - if all parameters are missing, than Creo use weight for sorting
    For examlpe:
    &asm.mbr.pozice Forward
    &asm.mbr.pro_mp_mass Forward
    6. SORT BY possibilities
    BACKWARD or FORWARD
    Search more info abou SORT TABLE or SORT BY PARAMETER:
    Hope it can helps
    Regards
    Milan Bonka
    Is there any way you know of to do this at the format level?
    When we start a new drawing, we would like the BOM to populate in order by part number.
    It currently orders it by the "description"
    It is a huge pain to need to organize it each time a drawing is made.
    In your drawing template, set the sort order in the repeat region so it formats the way you want.
    my tip...
    1.]
    Start with simple repeat region ... 1 column containin asm.mbr.name
    Is component order equal to model tree ? I hope so.
    Check repeat region attributes setting.
    2.]
    Go back to your table.
    Check repeat region attributes setting. Try to set it as in 1.]
    MH
