Datum tags - how to move them back?
  • February 11, 2016
  • 4 replies
  • 4222 views
By right clicking on a datum plane and selecting "Move Datum Tag", one can move the text location and Creo will connect the text with corner of the datum plane.
But how do you move this tag back to its default spot and remove this irksome line?
(Creo 2.0 M200)
18-Opal
February 12, 2016
Paul,
I found an old case, from another user, asking about the same behavior.  Unfortunately, there isn't an easy way to do this.  You will have to select a location near the original location to move the datum tag to.
Amit
psobejko1-VisitorAuthor
That doesn't actually remove the line.  Anyway, another little thing with Creo that is trivial and frustrating.
Why is there a line, anyway?  It just gets in the way, say on a drawing where one wanted to move the text of the tag in order to make a visual improvement.
If this is to be useful, you have to be able to move these tags / lines on the drawing, where it actually matters the most:
I have got the same problem using Creo 3.0 M080.
HamsterNL
18-Opal
March 9, 2018
Facing the same issue, moved the Datum Tag by accident...
Can someone with active maintenance post the contents of this article?
https://www.ptc.com/en/support/article?n=CS264295
Well, there's an article, but you're probably not going to like it. It goes like this:
Resolution
    Not part of the Pro/ENGINEER, Creo Elements/Pro and Creo Parametric functionality
    To request this functionality, refer to Product Ideas @ PTC Community
That's the full text of the "article".
11-Garnet
January 5, 2023
Patriot_1776
The solution is:
Don't move the tag.  😉
HamsterNL
18-Opal
March 9, 2018
Or use the Undo button (CTRL+Z)...oh...wait... Smiley Sad
