3-Newcomer
August 14, 2024
Different constraint sets for different simplified reps
  • August 14, 2024
  • 2 replies
  • 2336 views
is it possible to have different constraint sets for different simplified reps i have found a couple similar threads but they are all using it as a subassembly. such as this video.
https://www.youtube.com/watch?v=UHPnkSguUQE
Best answer by kdirth
The video is using flexibility to change constraint sets of a sub assembly when assembled.  Simplified reps cannot control constraint sets.  The best you could do with simplified reps is add the component twice, in different positions, and use simplified reps to pick which one to show.
kdirth
kdirth21-Topaz IAnswer
3-Newcomer
August 14, 2024
i was avoiding using multiple components for the simplified reps because my structure will then show the incorrect # of components, but if thats the only solution so be it.
3-Newcomer
August 14, 2024
do we know if this is possible in creo 10?
Sometimes its better to state your end goal instead of what you think your solution may be. Simplified reps have been  used for many purposes but it's primary goal is large assembly management.
Based on your end goal, maybe there are much better solutions!
