Dimension Round Off
  • March 16, 2017
  • 8397 views
All,
In CREO 3.0 M020...
I have a part in a drawing. I rounded down the decimals in the drawing. When I return to the model, the dimensions are rounded down per attachment "dim1" in red. In attachment "dim2", I click the dimension and it shows it's unrounded value. First of all.....the dimensions are in red. If I regenerate, they remain red. I guess I am used to the round off forcing the dimensions to be finalized per attachment "dim 1" after a regenerate in say WF5, the last release I worked in. What's the deal? Have I changed them or not? I like the idea of a show dimensions that are allowed to be shown 2 place on the drawing but remain it's logical 3-4 place in the model I think. However I imagine it would get into "what is your true tolerance intent?" Confused. Maybe it's too early still?
WayneF
Best answer by StephenW
Color schemes can be different but I suspect the red dimension are "locked" sketcher dimensions. 'Locked' as in they can't be changed by dragging.
Rounding, well, my suggestion is to look at the properties in the drawing and see if the rounding box is checked.
PTC definitely changed the settings so rounding became default at one point. There are config options to control this
StephenW23-Emerald IIIAnswer
wfalco16-PearlAuthor
Yeah ...looks like the check box for rounding does impact the outcome. I kinda like this. I think? So dimensions are show and I can control the places on the drawing....and the model remains as it was. However - I am getting the red dimensions. I went into the model and selected them all - then unlocked - then regenerated. There does not seem to be a consequence in doing this? They are now blue. I'll have to see how this plays out. Thanks for the suggestions Stephen!
I have conflicting opinions of rounding but I really want it to default to not rounded and then, if I want to, I can change a specific dimension to be rounded.
I believe I have my system set that way now but sometimes it's hard to tell with the mix of old and new parts/drawings.
Lock dimensions are ok. If they are not locked and they are strong dimension, you'll be fine. There was a pro/e-creo release at some point that made accidental dragging a problem but that has since been fixed. I rarely find a need to lock a dimension but I have seen others that lock everything.
