We solved the problem. The solution was to "customize ribbon" in the options. Selecting "All Modes" and expanding "dimension" and "tolerance" and the the "boxed Sec..." and then moving one of the <Unnamed> items back up into the box.
Though the solution seemed fairly simple we still may very well never know how this could have happened.
Hi @vincecatlin
Is it about tolerance in drawing dimension? You may try adding detail option tol_display as yes.
Thanks.
