Distributed Batch
I am working on a project in Creo 4.0 M090 to get a .tif file out for many of our models using the Creo Distributed Batch program. I came across 4 topics I need to solve if possible.
- Is there a way to have a certain layer turned off when the Dist Batch program uses Creo? We have a layer called THREAD that I need to turn off.
- I am using the No Hidden mode of each part model. Is there a way to control the thickness of the lines of the output for .tiff files? The default thickness needs to be increased.
- Does the Dist Batch program have any way to auto-crop to maximum size (boundary) of the model?
- Is there a way to set the default view as the standard orientation? Many of our users do not save the models in the default view.
Iām hoping there is a config.pro entry that works for these. I know there is a way to run a trail file with Dist Batch but that is not an option right now.
