Drawing Bug?
  • April 4, 2014
  • 2 replies
  • 1611 views
Hi Guys
We have Creo 2.0 M080, attached picture shows the problem. I have sectioned a welded assembly (tube and flange) but the hole drilled in the flange still shows on the drawing.
I have modelled and drawn the same assembly in the past with Creo Elements Pro with no issues, is this a bug and fixed in M100 or have I missed something?
Best answer by DieselPig
Thanks Antonius
Sorted! In Creo the command is Erase Cosmetic but it cleared the feature.
might want to keep an eye on this thread.
http://communities.ptc.com/message/238903
If that is a cosmetic feature, they can be problematic. You can right click on the view in the model tree and select Hide Cosmetics. I still haven't figured out the ins and outs of when these show up and how they print and how to manage them reliably. We get a lot of replies with "HLR" dependencies. Sometimes you see one thing but it plots another. I just put cosmetic threads on a "HIDEME" layer and manage them that way for each view as needed.
DieselPig1-VisitorAuthorAnswer
Thanks Antonius
