Dale_Rosema
Drawing changes
  • May 29, 2013
  • 4485 views
Some of my day consists of taking standard parts and making specials.
Typically this is just simple length changes per the customers requirements.
The question I have is with the way the drawing handles length changes.
If you have a partial view and the length is changed, why does the centerline and dimension not move with the end of the part relative to where they had been to the standard part?
The first drawings shows the part from the standard drawing.
The second drawings shows the part when, in this case, the part was made longer. The centerline of the notch of the tube is now where the end of the shorter, parent part would be given the new length of the part. Why does the centerline and therefore the dimension stay relative to this portion of the part that is in the view? This happens on several parts and several drawings when a part is either lengthened or shortened for a special.
If you had any suggestion how to keep the centerline relative to the portian of the view shown, I would appreciate it.
(FYI - in the second picture, you can see another centerline from a second view that has moved also, so it even happens multiple times in a drawing)
Thanks, Dale
Dale_Rosema
Here are a couple more screen shots.
Before the length is changed.
After the length is changed.
Dale,
do a simple test ... set view origin to some vertex on visible part of model geometry (by default the view origin is set in view center, therefore it moves when you modify model length).
Martin Hanak
Dale,
I tested your problem in Creo 2.0.
1.] in Detail view Creo does not enable user to set view origin
2.] I was able to reproduce the problem (axis moves after legth change). Try to open Case at PTC.
Good luck
Martin Hanak
