Drawing display of a cross-hatched 3D sketch - can't change spacing or angle
- October 18, 2021
- 1 reply
- 3375 views
Using CP4 M040.
In a part, I created a sketch and cross-hatched it. You can change the cross-hatch scale and angle.
In a drawing, I can't control its hatch spacing or angle. I can't pick it at all.
Goal: In a section view, I want to turn off the section's cross hatching and substitute my own. My sketch is intentionally drawn NOT to match the true section through the solid geometry. To get it to look right, I need to be able to adjust MY sketch's spacing and angle.
See screen shots and attached files. "Sketch 1" is the cross-hatched sketch. In the drawing, how do it get to have different line spacing and angle?
