8-Gravel
December 6, 2022
Drawing formats from Creo 5 not seen in Creo 8 to use??
  • December 6, 2022
  • 1024 views
Was wondering if someone could help or knew the answer this question? I am using Windchill and recently switched form Creo5 to Creo8. I'm trying to create a 2D drawing, I navigate to the correct directory where the template formats are and can't see them to use and select. Anyone know why I can't see and use them in Creo8? Do I need to create new ones?
Jeff
Best answer by BenLoosli
Check the location of Pro_Format_Dir in your config.pro.
Mine is set to a network location, but the default is to a folder under <Creo_Loadpoint>.
They can also be set to a folder in Windchill.
BenLoosli23-Emerald IIIAnswer
