Drawing not seeing model parameters
Was wondering if anyone can give me a clue as to what might be wrong with this drawing. Creo 3.0. First let me say that all my other drawings are behaving fine, it's just this one that isn't working. I have a model that has parameters for description, part number, revision, etc. I have a drawing with a title block that has those same parameters in tables. Normally changing parameter values in the model reflects in the drawing. But this drawing is not seeing the model. When I go to the drawing's Parameters pop-up, and select the "Look in" drop down, click part, the right drop down isn't showing the part listed, just the drawing. I went to Layout>Drawing models>Set model and the model is listed there. All the drawing views are connected and update as usual, it's just the parameters that aren't connecting. I've been having to update them manually in the title block. What am I missing?
TIA,
Bob
