Dwg imported image connection being lost in Creo4
If I import an image (jpeg, bmp, png, etc) into a drawing in Creo4, then move the drawing, the connection to the image is lost.
Also, If a drawing is moved, after an image is imported, and moved back to it's original location, the connection is lost.
This only happens with a created image; I added a ptc image (admittedly not designed for this purpose) to a drawing. After moving the file the ptc image still displayed correctly and there were no errors reported.
These are temporary images associated only with that particular drawing.
It is not advantageous to keep all images with the drawing nor in an image standard library.
I'm hoping there is a way to integrate the image into the drawing, making the external connection unnecessary.
