Edit Definition, remove transparency
  • September 28, 2022
  • 2201 views
hello, I know i was able to change this option in wildfire 4.0, however in creo how do you change it so that when you do edit definition the parts not being edited stay solid and not change transparent.?
Best answer by kdirth
I believe you are looking for Config Option - dim_inactive_components never
kdirth
kdirth21-Topaz IAnswer
Thanks so much, that worked!!
