Embedded Dimension problem
Gurus,
I'm trying to add a dimension in another dimension using the following
syntax
3x &d280 = @D
The value for &d280 will only show on model dimensions; however, I want
to show it in a dimension created in the drawing.
I'm pretty sure I have done this before so I wonder if it is a config
option or drawing option I need to set.
Any ideas?
Eric
Wildfire 4.0 Datecode m090
Windchill 9.0 Datecode m030
Eric
syntax
3x &d280 = @D
Any ideas?
Eric
Eric
