Export Parameter table as .XML file
Can anyone tell me how I can Export the parameter table in .xml format? I only have the option for .csv and .txt. I know you can export to .xml because I have done it before, but now the option is not available.
I believe there was a support article out of this.
Perhaps this applies to your case also?
Article - CS303553
File > Import Data/Export Data missing from Parameters window in Creo Parametric
Applies To:
Creo Parametric 4.0 to 8.0
Description:
Cause:
Resolution:
Br,
Lars
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
