HamsterNL
18-Opal
July 12, 2013
Export to IFC
  • July 12, 2013
  • 3 replies
  • 16971 views
We have the requirement to work in a BIM environment, by exporting our 3D models to the IFC format (Industry Foundation Class)
We have both WF4 and Creo2.0
How can I export my assemblies to IFC?
HamsterNL
HamsterNL18-OpalAuthor
18-Opal
September 26, 2013
Is nobody working with IFC?
Any PTC employee willing to comment?
Hello Teun,
This year I investigate the possibilities to convert a Creo Elements Direct Modeling model to IFC. If you been interested send your mail adres to CreoApps4You@outlook.com so that i can send you some information.
Best regards,
Ronald.
HamsterNL
18-Opal
February 15, 2014
Thanks for getting back.
Maybe you got my question wrong, but I am looking for a solution to EXPORT a PRO/E (or Creo) model to IFC. I am not looking for a way to IMPORT an IFC into PRO/E (or Creo). Besides...one thing which I noticed in your screenshots...did your "import IFC to Creo" smashed the modeltree into a flat structure? Does that mean that I need to spend time (money) to restructure the components into assemblies?
As far as LOD, any engineer who tries to export his complete assembly (with all the thousands nuts and bolts) to an IFC file should be fired on the spot. Simplified reps should be used to "trim the fat" and exclude the components which are not requried for the BIM model (like most of the nuts and bolts). Complex parts should be swapped with simplified representations, a shrinkwrapped model for example. You get the picture 🙂
Patriot_1776
I'm down with IFC (Yeah, you know me!).
(Sorry, a little "rap" humor from the early '90's)
HamsterNL
18-Opal
February 18, 2014
Frank, you are "naughty" (by nature) 😉
Patriot_1776
Hah! SOMEONE get's it!
I have tried exporting my model with the inbuilt IFC exporter. But I could only open it in revit as a single block, which was a big concern. After a lot of research, I tried a trial version of bim-dex plugin. It helped the IFC file maintain the classes and hierarchy inside revit as per my client's requirement. Hope this helps your use case too!
