Family Table Assembly with a Family Table component
I have an assembly which has a family table in it. There are two components in the assembly, one is a bushing and the other is a generic component from a family table. The bushing will be common in all assembly instances. In the assembly family table, I have the generic component in a column of the table, and have all the different component instances for each assemble instance. For example, my assembly has 3 instances, 111111-001, 111111-002 & 111111-003, and the component in the assembly that gets swapped out is 222222-001, 222222-002 & 222222-003. So assembly 111111-001 uses component 222222-001, and so forth.
So my question is on the drawing I have a table with a repeat region and want to have the component in each instance to show up in the table. I can't seem to make it work right. If I create a simple repeat region and use "&fam.inst.param.value" I can get the component to show up but all the other items in the family table show up too. I tried to add a filter to only show the component, but it doesn't seem to work. Everything else works, but the component one. To get by, I just created a parameter in the assembly, and have it in the family table and type in each component instance, and that fills in my table. But to me there should be a way to have the actual component populate the table since it's in the family table.
Thanks!
Ted
