First angle projection symbol
  • April 27, 2016
  • 2 replies
  • 7243 views
I would like to have the first angle projection symbol in my drawing template.  I have looked in Annotate>Symbols, but can't seem to find it.
Is this symbol a standard symbol in Creo? Or where can I find this symbol?
- Frederik
Best answer by BenLoosli
Create it yourself. It is well defined as to what it looks like and sizing.
Maybe someone will upload one.
It is not in the PTC distribution, and neither is the third-angle projection symbol.
BenLoosli23-Emerald IIIAnswer
No it is not a standard  symbol in PTC Creo Parametric.You would have to make that symbol and put it in drawing.
Seems like creating formats and drawing symbols is still in the dark ages. There should at least be some more commonly used symbols.  Most tutorials on creating drawing formats mostly criticize PTCs lack of functionality and suggest starting a new format with a legacy dxf format where ever possible. I'm sure explaining to management that we need a seat of Autocad to create better drawing formats will go over real well.
I found that by creating the border and margin lines first, then I added the zoning ticks by translate and copy. Did the same after placing the first zone letter/number. Translate and copy to complete the original row/column, then did a translate and copy of the whole row/column to the opposite side of the format. Now that I have the D-size and E-size formats, when I need something different, just swap out the tables and realign them. I have 3 different formats depending on which work is being done.
Tables placed in the drawing get copied to your drawing when used and they then are editable by anyone. Not sure if placing them in a drawing template will 'freeze' them. There should be a property value will lock a table if you are not in an admin role.
Originally, we did the tolerance block as a note in the part or assembly file and then put the note in a table on the drawing. A real pain if you have to make a change to the information, like changing from ASME Y14.5M-1994 to ASME Y14.5-2009 as your referenced drawing standard. I have now made the tolerance block a standard table with all the text rate than a part note. We have 4 tolerance blocks that the users can swap out, depending on what tolerances their drawing needs. I suppose they could edit one if they wanted to, but it might get caught when going through the release approval cycle. (I am an approver on all releases and I tend to look for things out of the standard. Since I created them, I find usually notice a difference.)
