Flexible Component
Let's say I have a 1-inch piece U shaped foam and I want to extend this foam around the edge of a rectangle shell with a 20 inch perimeter. My process was to constraint the foam onto the rectangle, and then use the "make flexible" tool to extend the foam. Now my issue is that I am not sure how to ensure that the foam follows just the perimeter of the rectangle (follow around the corners of the rectangle).
Maybe I am not using the flexible tool correctly.
Any tips on how to do this?
