Flexible component drawing
- April 22, 2020
- 2 replies
- 3173 views
Hello to all,
I created an assembly that contains a flexible component (spring_compression.prt) and I created two snapshots.
In 3d everything is updated correctly when I change the view from one snapshot to another.
In the drawing instead I created two views that recall snapshots but the spring does not update.
It appears as it is in 3d.
What can I do?
I don't want to create a family table because I have more complex mechanisms, with many positions to put in the 2d and they would become too many to manage ..
Attached are the files made with creo 6 and an image.
Thank you,
Matteo.
