Flexible component (torsion spring) controlled by angle
Hi I have a torsion spring which is modeled with relations to show it as near to real world as possible. This behaves correctly (as a stand alone model) adjusting the diameter, body height etc, when the parameters are modified within the spring design. The working deflection range of the spring is from 0° - 193° between the 2 legs.
When this spring is installed into an assembly and the spring is made as a flexible component and constrained by an angular positions in the assembly model. The flexible spring behaves correctly through the deflection range 0° - 179°, but anything over that, then the angular measurement is reversed. For example at full deflection on the assembly model 193° , the flexible component measurement analysis reads 167° ( i.e. 360 - 193).
In the assembly model the spring then appears disconnected.
There is no difference if the analysis plot is set to 0-360 or +/- 180.
The only way I have found to gain the correct measurement is to manually modify the angle measurement (flip the measurement direction by the arrows) each time the deflection angle goes either side of the 180° deflection range. This is an unsatisfactory solution, whilst dragging the model.
How do I control the way Creo measures this angle?, so that it reflects the working range (0° - 193°) of the components in the assembly without manual intervention each time I drag the model.
I am using Creo 8.03.
