GLOBAL CHANGES FROM ANSI TO ISO STANDARD
I have a complete machine assembly and I am now in Creo 3.0.
In the assembly view I can open up tree columns that I find useful as a global control of data to be added to fields.
I want to know if anyone has a command for the data field for the change over from ANSI to ISO standard.
Currently I have to open each file in turn and go thro sub menus:
PREPARE - MODEL PROPERTIES - TOLERANCE, this is very indirect, I want to access these from the top level Assembly.
Any help would be appreciated.
Francis
