Helical sweep with variable pitch vanes
  • January 13, 2014
  • 3 replies
  • 3395 views
Here's my issue, I am designing a part with a helical sweep where the pitch varies from 1.33 to 4.6. This part is no problem, the issue is we want to be able to mold this part and as you can see in the picture the vanes wrap around on themselfs. I think if I could keep the vane perpendicular to the asis it could be moldable. I've tried this using both helical sweep and swept blend to no avail. Thanks in advance.impeller1_10-14b.jpg
Patriot_1776
You will not be able to mold that as a typical 2-sided mold. With a helix thare's always the issue of negative draft/undercuts. You will need a spinning core, and even then, because of the change in pitch, it might not work. Depending on how soft the material is, you MIGHT be able to, with a ton of radial slides, pop th epart out with proper sequencing, but it goes back to the elasticity of the plastic.
Best of luck.
Frank is right, this type of part is made with investment casting.
Typically a lost wax master with a hard shell for the casting process.
If the material is a castable plastic, you might be able to get away with a flexible silicon mold where you could peel the mold away from the part.
Patriot_1776
'Sup Antonius! Yeah, I assumed he meant in plastic. That's gonna be pretty impossible to "mold". A spinning core MIGHT work, if the pitch change was in the other direction. Have to give it more thought......
I'll try and look at that stuff tomorrow!
That looks like a washing machine agitator? If molding is a requirement and you can vary the design, then you will probably have to do a lot of tweaking, like maybe being thicker towards the center but then having the profile change a bit at places where there will be parting lines.
bcooper1-VisitorAuthor
Thanks for the feed back.
The part is an impeller for a water pump and the intent of the project was to injection mold it. I couldn't come up with a way to do it and hoped you guys could but you did confirm that I was right.
thanks for your help.
Patriot_1776
Like I said, a spinning core MIGHT do it if the pitch was static, and the vanes were constant or decreasing in section. Conventional molding? Not a chance. It's just the geometry.
Patriot_1776
Yeah, there's a whole host of things you'd have to do. The variable pitch itself would probably be a show-stopper in itself, unless you made the vanes very thick at one end so that the tool would clear as it spun. If it was a static pitch, as long as you had HELICAL draft on the vanes, it'd work. I did something similar with a static pitch for a 6-lobed core (I believe it's in my photo album).
Flexibility of the part would help only slightly I think, you'd still have to worry about the tool shearing off the vane where it joins the cone, regardless of the outer edges bending.
Tough part to mold!
Question to the OP: Could the vanes be modified to make it moldable, of is that configuration absolutely needed for performance?
