Hiding sketches curves and Quilts in drawing
  • June 16, 2020
  • 3 replies
  • 8889 views
While creating a assembly drawing I am getting too many sketches displayed (in Pink and blue color) inside every views, its child parts are created with many features like merge, surface extrusion, cosmetic sketches etc.,
From top level assembly how can I hide all these sketches using layer and rules? instead of finding actual child part and hiding its sketch feature.
Best answer by ThoRig
Did the below link resolve your problem?
Mahesh_Sharma
22-Sapphire I
June 16, 2020
@RaJesh2
Check reviewing the layers in assembly and try control the visibility.
I had the same problem, and I posted the topic under Data Exchange.  Go to the attached thread and you will get your answer (I think).
https://community.ptc.com/t5/Data-Exchange/Cannot-Hide-Quilt-Edges/m-p/671220#M6443
ThoRig14-AlexandriteAnswer
Usually by default, Creo should have layer called 'sketch' , just click middle mouse and select hide and save status.
Cheers.
