Hole Command Defaults
  • February 10, 2026
  • 2 replies
  • 134 views
When I create a new hole in a creo model, is there a way that I can default to "Type - Standard" and also have the "Size - Thread type:" already looking at the correct .hol file?
Right now it defaults to "Type - Simple' and "Size - Thread type: ISO"
Thanks for your help!
Best answer by MORECREO
I wanted to stay clear from adding additional mapkeys at this point.
I found the following config option and its doing exactly what I was after.
!Option to load system .hol files
hole_load_system_param_files no
Thanks for all the replies. I appreciate all the help I continue to receive on this platform!!!
You didn't say what version of Creo you are using, but I think the preset functionality introduced in Creo 12 is what you are looking for.
https://support.ptc.com/help/creo/creo_pma/r12/usascii/index.html#page/whats_new_pma/core_presets_iFQA4.html
MORECREO14-AlexandriteAuthor
Thanks for the reply. I am on Creo 10
Does that mean I'm unable to achieve this? The presets looks interesting, I just don't need that level of customization at this point.
If at a minimum I could have it look at the correct .hol file every time I start the hole feature. That doesn't seem to farfetched?
I tried renaming the default .hol locations as well as deleting them entirely but they still show up and are the default selection.
MORECREO14-AlexandriteAuthorAnswer
In creo 13 you can do this with feature presets.
