How To check Comman Name through Model Check in Pro/E Wildfire 3.0
Hello Pro/E buddies
Good Day!!
I am setting up the model check config. files in my company. as per our practice the comman name should be XXXX; XXXXX(Example-TEST; MODEL). The designers must to enter comman name in this format. I want to add this check item to model check.
But I am not able to see any comman name check parameter in default_check.mcs file in proe wildfire 3.0.
If any one have any ideas that to check comman name through model check, kindly share with me.
Thanks In Advance
Suganthan Rajamanickam
Pro-e System AnalystTrane Design Centre, India
Ingersoll RandThis thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
