How can I add a hole driven by a relation?
  • June 20, 2022
  • 2 replies
  • 1448 views
I'm trying to create holes in a part that depends on its lenght. If the part has a lenght >= than 2000mm the hole should appear with a certain distance from the middle. If it's <= than 1000mm the holes shouldn't appear.
How can I do that? I tried to write it as an IF condition but the holes are appearing in both cases.
You mean you created a parameter, relations and put an IF statement in ProProgram?
Do you have a model to attach to the case? it will clarify your request.
Technically the extra parameter is not required.  The Pro/Program IF statement just needs to reference the length dimension.
Creo 7.0 sample part attached.
please create Creo files for testing purposes, pack them into single zip file and upload this zip file.
