How do you hide construction lines in drawing
  • November 21, 2016
  • 16618 views
I need to have construction lines to get intersections and dimension placements on a drawing but I can't seem to find how this is hidden.
I do however have a few solid lines and arcs that I would want displayed on the drawing.
Is there a way to filter by construction entities and blank these on a drawing?
Best answer by MartinHanak
you published picture of your drawing. Unfortunately I do not understand how construction lines were created. Are they draft entities created in the drawing ? If this is true, then hiding them using layer is the only way I know.
MH
can you upload some example data and pictures showing what you want to hide ?
MH
pimm15-MoonstoneAuthor
Martin
Here is a view of the type of entities I would like to hide.  See the type arrowed in green.
Since my post I have discovered that I can make a new layer to the specified entity type and specifically hide this.
Is there an easier way?  I would prefer to select all of a type and just right click hide, but that isn't possible that I can see.
Kevin:
Today I started a new drawing.  With some searching I was able to discern how to display datum axis with views so I know this won't move.
Unfortunately I have a large arcs which displays as segments of splines which looks like a construction entities would be necessary.
This originally would have been an arc, but through an intersection on the model it no longer displays as an arc.
There appear to be work arounds for different entities to display without need of construction entities; would this be an exception?
