How to add mass to a point
  • April 1, 2024
  • 2 replies
  • 4102 views
I have a 3D frame model and I want to add mass to a point to locate the CG of a component.  The Help section says to use the Refine Model --> Mass function to do this, but I haven't been able to locate that function on the Ribbon, or in any of the Toolbars.  Where is this located?
https://support.ptc.com/help/creo/creo_pma/r10.0/usascii/index.html#page/simulate/simulate/add_mass_pt.html
The article you linked is referencing the Simulate application. This is used for FEA.
FieldEng12-AmethystAuthor
Bummer.  Unfortunately, I don't have Simulate.  I didn't realize that's where I was copying the link from.  Thanks for the quick reply.
This pointed me in the right direction.  Thanks.  I was trying to assign mass to a datum point, but apparently I can't do that.  I tried to create just a point in a sketch and assign mass to that.  I can't finish the sketch, because it's just a point.  So I created a sphere and assigned the mass to that.  Then I'll locate the masses in the assembly to give the total package the necessary weight distribution.
Thanks for the help.
Sorry for the long delay in replying.  I went back to this topic this morning to see if I could implement what you were talking about.  I'm not sure that I follow.  I'm looking at the mass properties for one of my components.  I just created a sphere to represent the object in my assembly model, and I tried to assign a mass of 13,300 lbm to the object.  But, The inertia values aren't correct.  I made a solid block roughly the size of the engine, and the calculated mass using steel is within 300 lbs of the actual weight.  The inertias look much more realistic.  I can't figure out why I can't input the mass at a CG and come up with an equivalent inertia.
Mass sphere
Block mass
Thanks in advance.
