How to add mass to a point
  • April 1, 2024
  • 2 replies
  • 4102 views
I have a 3D frame model and I want to add mass to a point to locate the CG of a component.  The Help section says to use the Refine Model --> Mass function to do this, but I haven't been able to locate that function on the Ribbon, or in any of the Toolbars.  Where is this located?
https://support.ptc.com/help/creo/creo_pma/r10.0/usascii/index.html#page/simulate/simulate/add_mass_pt.html
The article you linked is referencing the Simulate application. This is used for FEA.
FieldEng12-AmethystAuthor
Bummer.  Unfortunately, I don't have Simulate.  I didn't realize that's where I was copying the link from.  Thanks for the quick reply.
This pointed me in the right direction.  Thanks.  I was trying to assign mass to a datum point, but apparently I can't do that.  I tried to create just a point in a sketch and assign mass to that.  I can't finish the sketch, because it's just a point.  So I created a sphere and assigned the mass to that.  Then I'll locate the masses in the assembly to give the total package the necessary weight distribution.
Thanks for the help.
18-Opal
April 11, 2024
The box represent 1 kg of water.
The size is 100x100x100 mm^3 with a density of 1g/cm^3 this equals to 1 Liter  10cmx10cm10cm = 1kg
Now I want that the weight is 5 kg
Alternate from  GEOMETRY to PARAMETER
PRO_MP_ALT_DENSITY enter 5 times more 0.000005 kg/mm^3 (PTC does not change this to the assigend unit g/cm^3 🙂
After Calculation (weired sh%$) the model weights now 5 kg if used in one Assembly.
You can do the same with all the other parameters.
