How to adjust the box command height in a text box
IA_11616046
2-Explorer
In a drawing in creo I am creating a notes section, but some of the notes are boxed. When adding a box, the height of the row increases from the text height. This causes horizontal misalignment in the column to the right. How can I add a box without adjusting the row height? Can the height of the box be reduced without adjusting font size?
I know of no way to do such a thing. This is how boxed text has worked for as long as I can remember. Makes a list of notes always look a bit off, in terms of horizontal spacing as well as vertical.
BenLoosli
(To:IA_11616046)
Put your numbering with the note text and you get a horizontal alignment.
FYI starting with Creo 10.0 you can use table to get following result. Creo 10.0 is able to blank all table cell lines.
Martin Hanák
